โMay-25-2015 01:06 PM
โMay-29-2015 12:20 AM
rferoni wrote:
snip.....Basically, after all is said and done, the front of my truck is within 5/8" of unloaded height. The rear of the truck though is squatting about 2" below unloaded height.......snip
โMay-28-2015 08:41 AM
โMay-25-2015 10:31 PM
โMay-25-2015 07:52 PM
โMay-25-2015 05:17 PM
rferoni wrote:
Ok thanks y'all. Right now that jack screw isn't even hitting/resting on the shank. Above the jack screw there is another sort of 'bolt'(not threaded) that has some washers on it. Looks like you could add/remove washers?? This part is resting against the shank.
I tried to go to 4 chain links but the brackets are so low I can't get the pipe underneath without the pipe hitting the ground. Yes I can get a different pipe or maybe put a bend in it just haven't had the chance yet.
I think the ball was tilted toward the trailer when we set it up. I'll get the ball straight(level) and redo everything from there.
Question...Do I adjust the tilt while everything is hooked up? I mean with the w/d bars tightened down and everything? If so, how exactly do I do that? Do I need to loosen the bolts holding the hitch head to the shank, or just crank on the jack screw?
Thank you all again for the input,
Ron
โMay-25-2015 03:59 PM
โMay-25-2015 03:50 PM
โMay-25-2015 01:52 PM
Rally's attended so far-21
โMay-25-2015 01:46 PM
โMay-25-2015 01:21 PM
