- dedmistonModerator"Hot Water Heater" bugs me too, but not enough to get as ugly as some of these posts.
- DrewEExplorer II
Boon Docker wrote:
way2roll wrote:
If you want hot air, use the furnace.
Yep, best way to obtain hot air is to use the cold air heater. :B
Or, if you have an old house with steam radiators, you'd have to fire up the cold water boiler.
I've never really understood the objection to "hot water heater." It's the heater for the hot water system, and so that name seems to me entirely reasonable. - Boon_DockerExplorer III
Yep, best way to obtain hot air is to use the cold air heater. :B - way2rollNavigator IIIf you want hot air, use the furnace.
- pitchExplorer IIHow many of you guys thought that the ever popular, "Why would you heat hot water?" was witty and original?
Betcha you're the life of all the parties! - spoon059Explorer II
Old-Biscuit wrote:
Ha, you mad bro? Didn't mean to make you cry... - mr_andyjExplorer
wa8yxm wrote:
Well why would you want to heat HOT water?
Wow. I sure hope wa8ysm is still not driving too.
Yes, it will light and heat. Some steel tanks are lined with an anti-rust coating and that will be ruined. Aluminum tanks may not be lined, so other than possible warping, I do not know what damage would occur. The propane will be much worse I assume than the electric element as the element is not touching the tank, but the propane flame is.
I accidentally had the electric on all winter, but did not keep camper plugged in too often as solar was on roof, but did have it plugged in plenty long enough to find out... and when I put water in there were no leaks. I t was well after that until I realized the electric was on, when I tried running the AC off a gen and kept tripping the breaker with both AC and tank on.
When gas is on at least it makes noise. - MFLNomad II^^^^^^^^
- Old-BiscuitExplorer III
spoon059 wrote:
Old-Biscuit wrote:
Water is only COLD upon initial filling.....reheat occurs when water temp gets to 110*F....that is still considered HOT
So get off the semantics Sheesh.
It heats cold water, it maintains hot water. Didn't know I needed your permission to comment about someone else's post, I'll consider that moving forward. - Boon_DockerExplorer IIIThis place is so funny at times. :B
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,117 PostsLatest Activity: Mar 12, 2025
