2005 coachmen 24foot travel trailer.
(searched and searched no luck finding help)
after winterizing(with air compressor)now all filled up and camping.the hot water isn't coming out.
Using the pump, hot water tank is working(propane, and tank is hot), pump is pumping great.
If he 3 way valve is straight the cold water works fine, but when i turn on hot the water bearly comes out.
If the 3 way valve is at the 90 degree water flows fine but it's cold
If i have the 3 way valve between the 2 it gets hot then cold then hot then cold.
I changed the shut off valve but same problem.
Save your Grandkids a job, BUY AMERICAN!
If the world didn't suck we would all fall off!
2005 Coachmen 24 TB
2011 Chevy Silverado
