NanciL's avatar
NanciL
Jan 14, 2017
How about this for "quality" work on our new trailer ?
Another of the many hidden item found on our new Forest River Trailer:
Yesterday I had the electrical load center apart checking out a circuit, and I happened to see two cables that were cut off at the connection where they come through the case. There was another along with them that came through and was in use.
I decided to check the rear of the panel and see where they were coming from, so I opened up the compartment and much to my surprise they were cut off on the rear also.
At the factory, the cable clamp that was used for the cable in use was three times as big as it should be, and some "brilliant" electrician just filled up the clamp with two more pieces of cable.
Now I know why when we pushed the remote for the main slide, the awning rolled down and when we pushed it for the awning the front stabilizers went down !
By the way, I was checking the panel to see about upgrading to 50 amps.
With that wonderful residential refrigerator and our 15,000 BTU AC unit, and the electric water heater, the 30 amp breaker will pop with the inrush of current if both the refrig and AC happen to turn on at the same time.
I wonder what we'll find next ?
Jack L
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 26, 2025
