robbie2013 wrote:
I have a 1024 Forest River Sunseeker 2650 with the E450 chassis and a V10. The question I have is how much car should I dingy tow? It appears to have a tow rating of 5,000lbs but would I hate my life if I maxed that out? I am getting 25L/100km (I am Canadian) so about 9.5mpg. How much will towing a dinghy car effect that?
Ideally, I want to pull a Jeep Wrangler, and they weigh about 4,000lbs. Do you think this would be too much and I should look at a smaller car?
I live in Alberta and camp in the Rocky Mountains, so I do end up on some long hills.
any advice would be appreciated.
you are wise to ask before purchasing a toad. many don't and live to regret that. before moving forward it's best to understand the various weight ratings on your MH.
- GVWR (gross vehicle weight rating): the maximum weight the chassis can support including itself.
- GCWR (gross combination weight rating): the maximum weight the vehicle can propel including itself.
- GAWR (gross axle weight rating): the maximum weight each axle can support. each axle will have a different GAWR. in a MH the sum of the GAWRs will usually, but not always, equal the GVWR.
- GVW (gross vehicle weight): the total weight of the MH as you have loaded it for travel. includes food, fuel, fresh water, clothing, supplies,
people, pets and stuff.
- GAW (gross axle weight): the total weight of the above loaded MH on each axle. please note that the GAW on a particular axle should not exceed that axle's GAWR.
- Empty Weight: the weight of the MH with full fuel and LP tanks but which is otherwise empty of food, fresh water, clothing, supplies,
- Payload: the difference between the GVWR and the Empty Weight and represents how much additional weight can be added.
you'll see a bunch of other weight ratings like CCC, sleeping capacity and the like. IMO those were designed to confuse the customer. although 'Empty Weight' and 'Payload' are no longer part of the parlance they are still most valid concepts.
load the MH as you would for a trip including fuel, water, food, clothing, pets, supplies and people. get individual axle weights and compare them to the GAWR for that axle. if either axle is overweight then either move weight to the other axle or eliminate the weight altogether. you need to check individual axle weights because it is possible to be under the GVWR of the MH even if one axle is overweight. I know from first hand experience.
once you know the various weights and weight ratings you can then do the following computations:
in general, the maximum amount of weight you can safely tow (diesel or gas) will be the
lesser of the following:
• the GCWR of the MH minus the actual weight of the MH as it is loaded for travel (includes fuel, fresh water, food, clothing, people, pets, supplies, etc.)
• the weight rating of your tow bar
• the weight rating of your hitch
once you know the maximum amount of weight you can safely tow how much of the max
should you tow? that's for you to decide but some folks limit towing to 80% or 90% of max while others tow to the limit...some beyond. I look at it this way...if exceeding limits weren't an issue then there'd be no limits.
good luck.
