Pineapple Kid wrote:
I spent a month trying to get rid of a nasty toilet smell . . . I attacked the problem full on . . .
- first thing I did was to climb up on the roof and remove the vent roof seal plastic cap thing and when I did the 1 1/2" abs vent pipe shot up in the air about 2".
- Not wanting to drop the Black tank I cut a 8" 10" hole in the paneling behind the toilet at floor level to take a look and sure enough the vent pipe was out of the tank and just sitting on the 2X2 floor joist. The vent pipe had been improperly installed at a cockeyed angle so it could not be fully insert into the collar anyway ( guess the skilled Amish at Jayco put the roof hole about 4" over to far for proper alignment ?)
- I heated the pipe a bit with a heat gun and bent it enough to fit down snug into the collar
- then filled the wall void around the pipe with a can of spray foam to keep it in place
- then Gorilla glued the cut out wall section back in place.
Oy veh!
While it's a good thing that you ended up fixing your defective Jayco, I can't imagine putting this much effort into curing the stink.
Long before cutting an
8' x 10' hole in my RV's wall, I would have just nuked the black tank with bleach.
