StarkNaked's avatar
StarkNaked
Oct 09, 2023
How to keep gray water from coming up into tub?
What do you do to keep gray water from coming up into the bathtub when you have to drive to the next dump station?
I tried buying a tapered rubber plug, but it's designed to keep water from going down the drain, not water coming up. With the shape of the taper, it just gets pushed up and out of the drain.
Have any of you come up with a good solution to keep water from coming up into the tub when you're driving on a curvy road?
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,129 PostsLatest Activity: Apr 26, 2025
