- harryjrExplorerhttps://www.rv.net/forum/index.cfm/fuseaction/thread/tid/30207130/srt/pa/pging/1/page/1.cfm
- StirCrazyModerator
Bobbo wrote:
You would lose that bet. There are videos of how to fully drain a Keurig. It is not a simple process.
it doesnt work all the time either...... I found out the hard way.
nothing like flashing up the kurieg in the spring to a counter full of water :R - Grit_dogNavigatorAbsolutely amazing that a topic like this could garner 4 pages of responses….
- magicbusExplorer II
Fisherman wrote:
Sounds like running vodka is the cheapest/best solution. I think I’d substitute bourbon to make the morning cup of joe a bit more fun :w.Bobbo wrote:
You're right, I just dismantled one to see the inner workings after it quit. Seemed like it was the pump that crapped out, but even turning it upside down and all other directions, about 1/2 cut of water remained inside.
Dave - FishermanExplorer
You're right, I just dismantled one to see the inner workings after it quit. Seemed like it was the pump that crapped out, but even turning it upside down and all other directions, about 1/2 cut of water remained inside. - BobboExplorer IIYou would lose that bet. There are videos of how to fully drain a Keurig. It is not a simple process.
- buckyExplorer III bet if you turned that sucker upside down the residual water would come out.
- BobboExplorer II
magicbus wrote:
For those wondering why the OP lets his trailer get so cold while he’s using it, it appears to be because when the temps are really low he stays in a motel. I suspect this is why he mentioned keeping it in the truck/motel for 3 days, probably while heading south.
Dave
Still, a Keurig is not so large or heavy that it is difficult to carry into the motel room on arrival, and back out to the trailer on departure. I would suggest doing so in a bag or sack of some kind so the motel detective doesn't think you are stealing THEIR Keurig when departing. - jkwilsonExplorer III
joshuajim wrote:
pbeverly wrote:
In regards to the landfills, K-Cups are recyclable. All the ones I buy state that and tell you what to do. Peal the top off, dump the coffee, rinse, put with recyclables.
Now, do I do this? NOOOO!! When they make it easy to pull the top off I will, right now it is a PAIN.
I use a cheap no name K-Cup brewer, OK, it has a name, but nothing I have heard of before, that makes a single cup and pretty much sucks all the water out each time.
Unfortunately, being recyclable does not mean it will be recycled. Because of the drop in recycled material value, pretty much only cardboard, some paper, plastic bottles and aluminum drink containers are recycled these days. It’s not cost effective to sort the other items so everything else goes to the dump.
If you don’t believe it, check with your supposed recycler.
Even plastic bottles are a hard sell now. Steel and aluminum is the only thing with any real demand. - joshuajimExplorer II
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 18, 2025
