gypsybyheart's avatar
gypsybyheart
I need help Winterizing Pace Arrow Vision
I recently inherited a 1998 Pace Arrow Vision 36B. Living in the Midwest I know that I need to winterize it so the water lines don't freeze. My dad always had the RV dealer do it (which was 5 miles down the road), my nearest dealership is more than 1 hour away.
My husband and I had an older park model trailer that we would blow the lines dry, then put antifreeze down each drain. From some of the post it sounds as if this is possible with the MH. I'm hoping someone who has, or had, a Pace Arrow Vision would be willing to share their knowledge with us.
We have an air compressor and really prefer this over putting antifreeze in the lines.
Thank you in advance for sharing your knowledge.
  • Sounds like you know what to do. Don't forget the water heater drain as well.
  • Get a blowout plug to connect your compressor air line to the city water inlet on your Pace Arrow.
    Then blow out the lines like you did with your park model.
    Check YouTube for instructional videos. It's really simple.
    RV Blowout Plug
