Sort By
- willaldExplorer III flat towed a 2014 Ford Taurus for several years, that had that same 65 mph restriction, and often wondered the same thing.
I never really got any answers on why Ford restricts it that way. I suspect, like you said, that it may be more about legal stuff than it is any physical limitation of the car to be flat towed faster than 65.
I did not make it a habit to go over 65 when towing the Taurus, usually set the cruise control at 65 when on highways. There were many occasions, though, that it did get over 65 for a minute or two when passing slower traffic, or when going through the mountains. It did fine, and car is almost 10 years old now, is my daily driver. It has over 70k miles (and probably 20k more in towing miles), and still drives fine, like new.
I'm not advocating that you can totally ignore that 65mph limit, as there may be a reason for it other than legal. Just saying, it probably won't be the end of the world if you occasionally do go over such when you need to, briefly.
Anyway, we now tow a Jeep Wrangler, that is much easier and more simple to tow, and has no such speed restrictions. The Taurus is still set up for flat towing and could still be towed, but we don't tow it now that we have the Jeep, as the Jeep is a much more fun vehicle to bring along. :) - CA_TravelerExplorer IIIFor me the biggest hazzard is the 4 wheelers. :S
- RetiredRealtorRExplorerIMHO:
1. 80 is too fast to tow in any situation . . . relax and enjoy the ride.
2. Don't relax too much . . . driving 55 - 58 on an interstate makes you a hazard. Those speeds are what secondary roads are made for. - CA_TravelerExplorer IIIMany don't. 62 for me in CA. OK I'm one of the many! CHP pass me without a glance.
And 62 in AZ where 75 is the minimum errr maximum. - Rocky2ExplorerDoes anyone bother with the posted speed limits when towing anymore? In the California Oregon border region, 80 or 75 seems a little high.
- CA_TravelerExplorer IIIAnd then there is the press. EV fires get a lot of news because the fires are difficult to put out and the resulting picture is newsworthy. But do they every report on the numbers? Everything I've read indicates the per 100,000 vehcles ICEs have much more frequent fires.
- CA_TravelerExplorer IIISpeed is also a safety factor. A slight variation in the road, wind, etc can have a larger effect on stability and should be a consideration.
And yes everything that the mfg publishes about a vehecle does involve their responsibility and libiality. But also our safety. - TreefrogExplorerThanks Charlevoix.
I usually cruise at 55 mph with double benefits: my navigator enjoys the ride more and I get almost 10 mpg.
However, but I loathe to waste the momentum gained downhill so let the speed rise to 75 mph guessing (without any training or knowledge except what you've shared) that the stress on the drive train will be minimal. - sundancer268ExplorerThe faster the speed, the more load on the drive train components. With the engine not running, the transmission is lubricated by the residual oil setting in various places. The engineers calculated how long this oil would last to provide for the safety of the transmission and it's longevity. You can tow at 80 MPH if you don't intend to keep the vehicle very long and will pass the problem onto the next owner. Why the rush, I set back at 58 MPH when the Allison shifts into sixth and enjoy the drive.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,131 PostsLatest Activity: May 12, 2025
