I apologize in advance for the long-winded question... Looking for feedback from anyone that has run the in-coil style supplemental airbags, such as the Load Lifter 1000 series from Air Lift. I re...
They work for me. I have them them in the front coils, and the van goes up and down when they are inflated with a load. I generally fill them up after loading, but sometimes I leave them inflated between loads and it doesn't make a difference that I can tell. Beware that adding the load after initial inflation will make psi go up. So don't start at 50 psi. Maybe start at 25 psi, add the hitch weight, then check the current pressure.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
