In subframe and Jeep
wolfpac71
I tow a 2014 Jeep Wrangler equipped with an Invsibrake System. I had a direct charge line installed on the battery. I still experience "low battery" after a couple of days of long hauls. What might cause a battery drain with a direct charge line installed?
5 REPLIES 5
FIRE_UP
wolfpac71 wrote:
Mody n Domy, thanks for your response reqarding the battery drain issue with the Invsibrake issue. Since I already have a direct charge line installed, would that have to be removed prior to installing the Toad Charger?
Before you go changing anything or, jumping to conclusions, there's a couple things to check first. The first thing I'd check is, make sure that your "direct" charge line to the toad, is working and, working all the time that it's supposed to be. Did you install this "direct" charge line? If so, or, even if you didn't, is there a fuse in the system or, a possible automatic reset circuit breaker that, neither of which, maybe working??? Or, maybe the wiring of the direct charge was done with too small of wire and, is not conveying the proper voltage/amperage to the toads battery. Just ideas here.
Next, I'd call the Invisibrake folks and find out, just what kind of amperage draw that unit is supposed to impose, on the toads 12V system. As has been suggested, it's possible that, the load of the Invisibrake, is exceeding the supply of 12V (that may or may not, be accurately working). Once you find out this info, then you can develop a course of action.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
wolfpac71
Mody_n_Domy
If the Invsibrake is plugged in a 12v outlet in the Jeep that is your draw. I installed a Toad Charger to keep the battery charged while my Blue Ox Patriot is being used.
2008 Damon Challenger 378 on Workhorse chassis, 2008 HHR panel toad.
Y-Guy
Moderator
Moderator
The Invsibrake System is probably your drain as in needs power. Question is if the charge line is working or providing enough power to offset the Invsibrake System. It appears it's not. Perhaps the trickle charge line needs to be checked out. You're sure you're following the proper steps to tow, key in the right position?
Two Wire Fox Terriers; Sarge & Sully
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
SoCalDesertRid1
Something's drawing juice off the battery, or you have a short.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
