MRO2009's avatar
MRO2009
Installing new vinyl trim inserts, caulk or no caulk?
So I replaced/repaired my roof this summer on our hybrid travel trailer, and as part of that headache, I replaced some of my aluminum trim pieces along with all new white vinyl inserts and #10 screws. Obviously, the vinyl insert is NOT waterproof, but I have heard several folks mention that it waterproofs the trim and not to skip that step. In my opinion, the loose-fitting vinyl insert was never designed to be waterproof and is really just for aesthetics to hide the screw heads. During disassembly, I did find a lot of evidence of water that had gotten behind my old vinyl trim inserts. Subsequently, many of my trim screws were heavily rusted, which may be because of trapped water behind the vinyl trim. Just an assumption, but the water had to have been getting in somewhere to rust so many screws. I found two spots where the roof was leaking when I removed my old rubber roof but hard to say if that's what caused the trim screws to rust or perhaps water trapped behind the vinyl insert trim. So for installing new vinyl trim inserts, I've seen some YouTubers caulk both edges where the insert goes into the trim channel and was wondering what the school of thought is out there in the community. To caulk or not to caulk?
  • deltabravo wrote:
    StirCrazy wrote:
    It doesn't make sense to back each screw out to add a dab of caulk and retighten them all. But thanks for the suggestion.
    I installed stainless screws when I did the project: Screw upgrade
    um you quoted the wrong person here.. haha
  • MRO2009 wrote:
    There is new butyl tape behind every piece of trim that was removed and replaced. And all new screws were used in the rebuild which is already complete. It doesn't make sense to back each screw out to add a dab of caulk and retighten them all. But thanks for the suggestion.
    actually, it does, as you don't caulk the vinal insert and you have made a path that the water can migrate down the screw head. The vinyl strip is just for looks, to cover up the ugly screws. now having said that the factory doesn't put silicone in the screw holes which is why we get rotting wood and rusted screws. it wouldn't take much to do it if you haven't put the vinyl strip in yet.
  • That trim does not receive caulking, at all. Despite what anyone might say.
  • I installed new insert at the roof. I use sealant a the very ends and also in each screw hole. I also upgraded to stainless steel screws.
    Here's a few videos I did on the project:
    Install new vinyl trim insert
    Screw upgrade
    When installing vertical sections of trim, you don't want to seal the bottom. Photo in the post above mine shows that quite well.
  • Note that vinyl shrinks with age. As many other report, the arch just above/behind the drivers/passenger doors on Class C's pull out over time due to this shrinkage.
    Rather than replace the length, I pull it up from the bottom, then add a small piece below to complete the fill, like this:
    The small piece was a tad narrower, so it didn't bulge out like the original, but still did the trick. I added an external stainless screw to hold everything in place.
    As others report, seal each screw head before inserting the vinyl strip
    For those of us who use our rig occasionally over the year, a big part of preservation is storing your RV under a solid cover or in a garage/shop to keep it out of the elements. It's not possible for many folks, but it sure makes them last a lot longer.
  • I just replaced the vinyl on our Momentum, and didn't use any caulking.
  • There is new butyl tape behind every piece of trim that was removed and replaced. And all new screws were used in the rebuild which is already complete. It doesn't make sense to back each screw out to add a dab of caulk and retighten them all. But thanks for the suggestion.
  • I did what MFL did when I replaced the vinyl trim. New stainless steel screws with a dab of caulk before tightening them down.
  • No need to caulk vinyl. When replacing rusted screws, that is the time to put a dab of caulk/sealant on the new screws, prior to snugging them.
    Jerry
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
