Sep-01-2015 07:12 AM
Sep-09-2015 03:19 PM
JD and Beastlet wrote:chracatoa wrote:
Also, dial your breaks correctly or every time you break on the highway you will feel a pull to the left or right.
If the trailer brakes are not working properly on one side I suspect it would pull to the other regardless of what hitch you're using.
Sep-09-2015 06:52 AM
Sep-08-2015 11:13 AM
Goo wrote:
I found that mine was quite easy. After it was set up so that the trailer was level, I tightened the bars so that 1/2 the front end lift came back down (per Ford manual). I actually marked that spot on the spring bar jacks with a yellow paint pen. Now every time I hook up, that's where I crank it to.
Goo wrote:
If i find the ride a bit too bouncy, I'll lower the jacks a bit to put more weight on the tongue, but generally speaking the setup is not finicky at all.
chracatoa wrote:
See if you get the weight distribution part right otherwise you'll bounce around (though you have a 2500 so you may not feel it). Also, dial your breaks correctly or every time you break on the highway you will feel a pull to the left or right.
Sep-06-2015 07:32 PM
Sep-03-2015 06:32 PM
