docsouce's avatar
docsouce
Sep 30, 2020
King Jack Directional Antenna Protection
My 2020 26XD has the King Jack antenna. Before I put the winter cover on do you think I should make up a cover to go over the antenna? The antenna cover would have a wide base flat to disperse the weight of the heavy snow/slush/ice we get here in Southern New England. I'm thinking the weight of this wintery mix will put a lot of downward pressure on the winter cover and on the small surface where the antenna mounts to the roof and possibly cause roof damage or breaking the antenna. My other Class c was the crank up/down type and this wasn't an issue.
  • Humm,, never thought of it before but, it is probably not a bad idea to cover it with a box or tub as the other posters have said. Skylights too.
  • Lynnmor wrote:
    Maybe you could put a sturdy plastic tub over it to spread the load.
    Yeah that's what I see. People use those large round bottom hanging plastic planters. Since they are round bottom, when placed over the antenna they form a dome. I have also seen laundry baskets and the plastic tubs. Here's it's usually the summer covers (winter we're out and about locally) so those thinner plastic items tend to get too soft, but in colder places, they should hold up very well.
  • Maybe you could put a sturdy plastic tub over it to spread the load.
  • Well I'm on the other side, I made 2 boxes, one to cover the antenna and one to cover the flimsy skylight before the cover goes on in a couple weeks. Both boxes are made from 1 x 6 cedar fence board, very light weight.
  • Everything on the RV was designed to be outside and unless you are parked under a tree or some structure that might fall on the roof, I would leave it as is.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,129 PostsLatest Activity: Apr 26, 2025
