- JIMNLINExplorer III
pasusan wrote:
SDcampowneroperator wrote:
Modern absorption reffigerators tolerate 3 degree side to side, 7degree front to rear off level for extended times without harm. If you can walk in the unit without troubles, your fridge is fine.
There was a time when perfectly level was critical, no more.
Well, what does "modern" mean? What's the cutoff year that makes it not so critical?
IMWTK :)
Some time in the 1987-'88 era.
I parked my then new 1984 Aljo 5th wheel trailer beside my barn on limestone crusher run. The barn protected the trailer from the sun however north/south and east west was not level. After 5 years or the Dometic fridge quit cooling (strong ammonia odor). Hole burnt in the tube caused by operating quite a bit out of level.
Replaced the old Dometic with a new one which came with the new 3 degree side to side operation. - The old fridges with a pilot flame seemed more sensitive than the modern 2-way fridges of today that are quite tolerant.
For storage or non-use as long as it is somewhat upright all will be fine. - Grit_dogNavigator
Brownleaf wrote:
Does my motorhome need to be level regrding the refrigerator if it is not being used? Doug
Not in use, shut off? It absolutely doesn't need to be level or even close to level. You could store it on it's side of you want to... - TurnThePageExplorerMy 2004 travel trailer manual states 3 degrees side to side and 6 front to rear.
- pasusanExplorer
IMWTK :) - BrownleafExplorerIts a 2004 absorption type. Doug
- If it’s one of the new 12 volt compressor fridges it doesn’t matter if it’s running or off.
- Grit_dogNavigator
OP
^This, for when operating/in use. I've seen 3&6 deg as published limits before.
Remember this is with respect to how the fridge is oriented, not the camper. - opnspacesNavigator IITrue for a running refrigerator. But for this question the refrigerator is turned off. If the refrigerator is off it does not need to be stored level
- SDcampowneroperExplorerModern absorption reffigerators tolerate 3 degree side to side, 7degree front to rear off level for extended times without harm. If you can walk in the unit without troubles, your fridge is fine.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
