DinTulsa
Jan 27, 2016Explorer
From Maxxis regarding inflation pressure. According to them, running at less than 80psi does not hurt them. I will however be running them at 80, I called and determined that my wheels were capable of 80psi.
Your inflation pressure should be determined by your maximum loaded weight. If you know what that is you can check here to determine the proper inflation:
http://www.maxxis.com/trailer/trailer-tire-loadinflation-chart
Inflating a tire to less than it's maximum will not effect the tire's durability or performance.
Thanks for you inquiry and recent purchase of Maxxis Tires.
Best Regards,
Your Maxxis Support Team
Best Regards,
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
