- philhExplorer IIElectric is easier, end of story
- LantleyNomad
Old-Biscuit wrote:
Lantley wrote:
blaczero wrote:
HappyKayakers wrote:
I found this link several years ago. Can't vouch for the figures but it looked like someone did their homework. http://www.adventure.1tree.net/index.php?option=com_content&view=article&id=292&Itemid=285
Good info everyone thanks. Great link too.
I'll do some calculations and go from there.
The inconvenience doesn't factor in, since my campground has propane fill and it's $25 for a 30#'er.
I assume you have permanently mounted tanks and they come to you with a truck. Otherwise there is a convenience factor. Even then you have to arrange for LP, pay for it and meet the driver to fill tank.
With electric there is no interaction. NONE.
OP stated
I would assume portable propane cylinders
If the OP has portable tanks, than there is a convenience factor. Unless the CG changes the tanks for him for free, otherwise the OP has to physically put in the effort to swap the tanks. - Old-BiscuitExplorer III
OP stated
I would assume portable propane cylinders - LantleyNomad
With electric there is no interaction. NONE. - blaczeroExplorer
The inconvenience doesn't factor in, since my campground has propane fill and it's $25 for a 30#'er. - Michelle_SExplorer IIII have twin 40 Lb Tanks and those things are heavy when filled. I'll use electric every chance I get to avoid having to refill those beasts.
- theoldwizard1Explorer IISomeday, we will be able to purchase GOOD RV heat pumps, ones that will produce heat down to zero F (like mini-split heat pumps that have been around for decades).
One more nail in the coffin for LP in an RV ! - Super_DaveExplorerI don't know about your campground but we are also at a seasonal site and we don't pay for metered electrical use unless we go over our base allowance per month. Over the past few summers, frig and daily air conditioning didn't put us over our allowance.
Lantley wrote:
valhalla360 wrote:
Cost really is a non-issue in the choice.
Unless you use a ton of propane, the convenience of electric makes it worth paying an extra $5-10 per year with electricity.
If you use that much on a seasonal site, see about getting a propane company to bring out a big 100gal tank but unless you do a lot of winter camping, it's unlikely to be worth it.
This^^^^. Why go through the effort of monitoring and changing tanks.
Electric does not require any input from the end user.
The cost difference is negligible either way.
A few bucks either way
Electric is so much easier
Fridge.... might have TWO 225W elements (large size) or ONE 375W element (medium size)
Propane ---1200btu to 2200btu depending on size of fridge
Water heater.....
Atwood 6 gal 8kbtu/hr --10kbtu/hr 10 gal ---1400W element
Suburban 6,10,12,16 gal---12Kbtu/hr run time ---1440W element
Do the math
OR
Use the electric it isn't going to be that costly - Cummins12V98Explorer IIIThink about your time and vehicle wear and tear plus fuel consumption to take the tanks to be filled. I really don't care about the cost I run electric when possible for everything.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 26, 2025
