itguy08's avatar
itguy08
Making sense of Tow #'s
Looking at buying my first truck and need some help with Towing. We're planning to get an RV in a year or 2 and I want it to do it right the first time!
Looking at a 2011 F150 Supercrew Ecoboost with Max Tow. According to the Payload on the door jamb it's 1850 lbs and Ford says it can tow 11,200 lbs.
Now we've been looking at RV's for a few years now and like these:
Jayco 33RLDS
Jayco 26RKS
Lacrosse 323RST
Lacrosse 327RES
Prowler 30PRLS
Outback 316RL
All have gross weights between 8,400 lbs and 10,300 lbs. and about 30-36ft. I worked up a spreadsheet based on 10 and 15% tongue weight and it looks like at 10% we're good as we have 820 and 1010 payload left. At 15% it gets a lot closer and in some cases only 300 lbs.
Is this doable and with a Weight Distributing hitch would it make sense or should we be looking elsewhere?
Also the #'s I came up with on young weight are much different that the RV brochures. Is that normal?
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,106 PostsLatest Activity: Jan 27, 2025
