Mar-09-2021 02:46 PM
Mar-10-2021 03:48 AM
Mar-10-2021 12:25 AM
dedmiston wrote:
I'm no engineer, but I assume you're going to trench down and pour footings for the retaining wall?
As for the final slope, it's good to have some pitch to it for drainage, and then you can use blocks for final leveling if you need to.
Mar-09-2021 07:54 PM
trcothorn wrote:
The drawings really help put everything in perspective thank you. I decided to make the pad shorter, closer to just behind the rear axle, instead of the full length of the trailer. Thanks for all of the suggestions
Mar-09-2021 07:20 PM
Mar-09-2021 07:16 PM
trcothorn wrote:
This is the set up I’m going for. Gravel base for drainage, deadman tee anchors for support. All that.
Mar-09-2021 06:09 PM
Mar-09-2021 05:26 PM
trcothorn wrote:
So my question is, for every 4ft there is a 9.5 inch drop. My trailer is 30ft. So do I divide 30 by 4, and times that by 9.5 to figure how to get level? Doing that tells me I need a 71 inch wall to get level. Am I doing this all wrong or over thinking it? Really would appreciate input on this my brain is hurting.
Mar-09-2021 05:15 PM
trcothorn wrote:
I ran a string line to measure my retaining wall height. If I have the line 3 feet above the ground and check the line for level, it is still just barely sloped back. I do not want to build a wall taller than 3 ft due to increase chance of the wall leaning or giving way. So I went inside the trailer with my 4ft bubble level and measured, if I rise the back of the bubble level 9.5 inches it shows level.
Mar-09-2021 04:44 PM
Mar-09-2021 04:40 PM
rhagfo wrote:
Nice, but you considered the larger concrete retaining wall stacking blocks? Build a good base packed crush stone, keep it level.
Mar-09-2021 04:36 PM
Mar-09-2021 04:32 PM
Mar-09-2021 04:28 PM
Mar-09-2021 04:27 PM
Mar-09-2021 03:53 PM
