- HuntindogExplorerPerformance is very close to the same, though the way they achieve it is somewhat different.
Installation, is the big difference. The DC is fussier. And it will have less ground clearance. That was the deal breaker for me. I want all the ground clearance I can get. - TXicemanExplorer IIThe Reese Dual Cam is a well proven hitch and I would consider a step down to the 4-point.
- Ron3rdExplorer III
ChooChooMan74 wrote:
Has anyone gone from towing with a Reese DC to an Equal-I-zer 4 point hitch? Did you regret the decision? Anything you miss about the Reese? Anything you don't like about the Equal-I-zer?
Only downside to the EQ is that they can be noisy. They moan and groan at times. - dodge_guyExplorer III`ve only had the DC. In looking at both hitches I feel the DC can do a far better job at keeping sway from starting an/or continuing!
Go with the DC. - ChooChooMan74ExplorerI guess I will get the Reese DC when getting my new truck/trailer. I had put that I was considering letting the hitch go with the trailer, but that got modded out.
- fla-gypsyExplorerAfter adding the HP Dual Cam several years ago I cannot imagine anything working better or needing to work better.
- JBarcaNomad IIBoth hitches are good.
If you are having a control issue, switching from the EQ to the DC will not correct it. Or visa versa. We may be able to help optimize what you have to find the problem. Is there a problem and what is it?
That said, which Reese WD hitch do you have to go with the DC? The round bar hitch or the trunnion bar? There are certain limitations with the round bar system pending your setup being able to adjust the WD optimally. This generally occurs when the loaded TW gets close to the WD bar rating. This can be a problem with the Reese round bar hitch when used with the DC. The amount of head tilt is very limited. However knowing the problem, there are some things that can be done to help it.
Let us know more and we may be able to help
John - ChooChooMan74Explorer
ScottG wrote:
So, you went the other way, and you like the DC better. Wow, good to know, thanks.
I went from the equalizer to the DC and would never go back. However, there are some newer designs out there that look very good, like the Blue Ox and similar systems with some kind of spring built in. - ScottGNomadI went from the equalizer to the DC and would never go back. However, there are some newer designs out there that look very good, like the Blue Ox and similar systems with some kind of spring built in.
- tonymullExplorerNever used the Reese, but I can tell you that there was nothing I didn't like about the Equal-I-zer.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
