My FW has Pimples and it is not a teenager.
TenOC
I purchased a used 1 year old Fifth wheel from a private seller. After I got the FW home I noticed that on the back and also on the side wall there were groups of "pimples" on the wall. I first thought that it was here stales or nails were too long and during construction they almost came though the wall, but there are too many for that. Maybe sand got between the wall and the laminate during construction?????
[img] Click For Full-Size Image. width=640[/img]
Any Suggestions ??????
PS: I was trying to use RV.NET: Photo Upload & Post at http://photoposting.is-great.net/ to post the photo. I click to may full size. Will attempt to post with out full size
Photo # 2
I found how to post the photo. I copied the Copy and paste this code into your post: and pasted the code. Do not use the Insert photo icon above.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
9 REPLIES 9
John_S_
Out gassing of the fiberglass. It should come inwards and not show with the insulation.
John
2015 Born Free Royal Splendor on a Ford 550
2018 Rubicon
Boo Boo a Mi Kie
42' 36' & 34 Foretravels sold
2007 Born free 24 sold
2001 Wrangler sold
2012 Jeep Grand Cherokee Overland sold
Susie Dolly, Lolly &Doodle (CKC) now in our hearts and thoughts
in5r
While this is a sign of a possible water leak it could also be from a higher amount of moisture trapped inside the rv from cooking,steam from a shower/tub etc. We had the same sign and it turned out to be water intrusion from a bad window seal resulting in complete replacement of our real wall under warranty.
2019 Ford F250 6.7 CC SB
2015 Jayco Eagle HT 28.5RSTS
Ralph_Cramden
A classic sign of water intrusion. It does not take much. That blistering condition pops up in RV forums every so often, and in every case I have read and followed a leak was eventually found.
Too many geezers, self appointed moderators, experts, and disappearing posts for me. Enjoy. How many times can the same thing be rehashed over and over?
newman_fulltime
offgassing bubbles from moisture coming out of the glue
wing_zealot
Stick a pin in one, I'll bet a water drop comes out.
TurnThePage
I noticed those on my trailer a few years ago. I dunno what they are, but I don't think they are water damage. They are hard, and the wall is still firm. There haven't been anymore of them since the first time I noticed them.
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
Wanderlost
Nomad II
Nomad II
Spousal Unit suggested it might be polyestermites...
"The greatness of a nation and its moral progress can be judged by the way its animals are treated." -- Mahatma Gandhi
Czarny, black cat
Rainbow Bridge: Spotacus, Alexander the Grrreat, and so very many more
azrving
Corkey05
It's hard to tell, but it looks like the grain has lifted from the plywood panel behind the wall cover.
It may have been that way for a long time (even new), or it may be a new condition (still grain lift) usually caused by moisture.
All you can do is watch a target spot and compare photos to see if it's progressing. If not there's not much you can do or worth worrying about. If it grows you have a water intrusion problem.
2008 HR Endeavor PDQ - Ford Edge 4 Down
FMCA F374292
