Terryallan
May 17, 2018Explorer II
Lynnmor wrote:Terryallan wrote:Lynnmor wrote:
I would try to find a way to fix that Brakesmart, MaxBrake is also out of business and there are no controllers available that use your foot pressure as a reference. You likely will not be happy with the guesswork controllers that can only apply the brakes if your tow vehicle already has the ability to slow the combination.
Actually, That is not true. The Prodigy, and well every controller will apply the trailer brakes when you pull the manual lever. Weather or not the TV is braking. It is simply the best after market controller currently on the market. Millions of trailers are being stopped by some version of the Prodigy.
Now the Ford Factory brake controller will send braking current dependent on how hard you press the brake pedal. But with out a factory controller, prodigy is best
Actually the Brakesmart works like the Ford controller, a much superior method than the plug and pray guesswork controllers that you suggest.
then go buy one. Oh! You can't. they don't make them any more. Which goes back to my statement. The Prodigy is the best after market controller currently on the market.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 18, 2025
