- packnratExplorerbut a couple sets of these.
https://www.amazon.com/Original-Sheet-Suspenders-fasteners-Adjustable/dp/B00451BG2G - I like my custom sheets in the RV. Can get the flat sheet extra long to be sure it tucks in a little extra as you like. Or extra wide if sharing is an issue. Then I would be getting the suspenders/keepers if needed.
+1 for Costco if the mattress is an exact fit standard size. - JAC1982ExplorerThe Charisma brand sheets from Costco work great on the king size bed in the camper.
- johnhicksExplorerWe have fitted sheets for deep mattresses (queen) which work great. Mom found them on Amazon.
- momentum_rvExplorerThere are fitted sheets for thicker mattresses. Might work better.
- Nutinelse2doExplorerI have found California King sheets fit the best, with no straps or mods.
We have an egg crate pad under the mattress so it doesn’t slip on the pedestal.
Maybe that traps the sheet corners?? - Dutch_12078Explorer IIWe use sheet suspenders as well for our "RV queen" mattress fitted with standard queen sheets. We found the three way style works best for us.
RayTour Bed Sheet Holder Straps - MerrykaliaExplorer
GordonThree wrote:
Janss wrote:
Here's what I use:
Sheet Suspenders
Ditto for suspenders
Use these, also, but got mine at Wally World for about $4/set. I have two sets on the RV King. - GordonThreeExplorer
- We got one of those non-skid pads meant to place under an area rug and placed it under the mattress. It does 2 things... keeps the mattress from sliding down the slippery wooden platform it sits on, and it also helps hold the fitted sheet in place.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 18, 2025
