hemanthariyani
Apr 12, 2014Explorer
Newbie looking for help with WD+Sway Control
Hello all,
I am a total newbie in the world of towing having just bought a Tow Vehicle and a Travel Trailer and I am looking for some help with an appropriate hitch/sway control setup.
My Tow Vehicle is a 2006 Dodge Ram 2500 Diesel and my travel trailer is 33 ft long with a dry weight of 6900 lbs and GVWR of 9560 lbs.
Based on whatever I have read and learnt from this forum and others, I believe I need a WD hitch with sway control and the tongue weight is in the range of 800-1200 lbs.
Now, my RV dealer is suggesting installation of EAZ-lift hitch+sway control for arnd USD 520 + tax and I believe it has 1000/10000 lbs. I feel that this is too expensive for that hitch and is at the limit of my setup. Am I right in my assumptions?
Having read multiple discussions on this topic, most people seem to go for Reese DC or Equal-i-zer 4 point SC with eq being slightly easier to setup. I am thinking of getting eq.
I will be really grateful if I can get some help:
1. Do I need 1200/12000 or 1000/10000 limits or something else?
2. I am getting some good used deals in my area and I am also getting some decent deals for new ones online. Is this something I can set up myself? I do not have experience with hitches and trailers but I am quite comfortable with DIY stuff in general.
3. If I need to tow the trailer from the dealer's location to my parking lot without the WD setup being available, is it okay to tow with just a ball for around 30 miles (I will need to buy a ball as well)
4. What do I need to look for when buying a used hitch? I saw one that was used for a couple of years but has quite a bit of visible rust.
5. Anything else I need to consider?
Regards
Hemant
Regards
Hemant
