- Margos_ExplorerI use a yoga mat for the big shelf. Nice and thick.
- dvitale300Explorer
downtheroad wrote:
3/8" is almost a half inch thick..seems excessive for a shelf liner.
Maybe some kind of cushioned rubber mat that you can cut to size.
Doubt you will find true "shelf liner" that thick.
Agreed! We use the porous 'rubbery' type from the housewares / kitchen section of walmart. It's cheap and does the trick. - downtheroadExplorer3/8" is almost a half inch thick..seems excessive for a shelf liner.
Doubt you will find true "shelf liner" that thick. - tycreekExplorerMaybe Look for tool box liners? Though 3/8" is thicker than I've seen.
- GordonThreeExplorer
bunyon14 wrote:
Looking for non slip shelf liner that is about 3/8" thick.
The thick stuff is in the area-rug department, as it is used for non-slip liner under small rugs and mats.
I have also seen it in the bedding area as a liner for under a mattress to prevent sliding. - bukhrnNomad
TxCowboy wrote:
This is what I use, but I have to ask, Why 3/8" ?
You can find it almost anywhere, including Wal-Mart, most home supply stores, etc. Look for it in the housewares section and in the RV section. It runs about $4 for a 25 foot roll when I purchased my last roll.
BTW, I assume you're talking about the semi-porous matting that you can trim with a scissors. - TxCowboyExplorerYou can find it almost anywhere, including Wal-Mart, most home supply stores, etc. Look for it in the housewares section and in the RV section. It runs about $4 for a 25 foot roll when I purchased my last roll.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 21, 2026
