georgelesley
Aug 02, 2020Explorer
Update: this AM on lp all nite, refer was 30-32, freezer was +4. Switched to ac operation one hour later same numbers. All appears good. I will likely change the circuit board proactively.
BTW, we have the Amish cooling unit, and they installed two external fans when the cooling unit was installed, as well as a permanent internal fan. The boiler and heat tube coil was about 100 deg today and all seems normal. I backed the temp control off from the 4 setting to two which is our normal setting except in very warm conditions.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
