georgelesley
Aug 01, 2020Explorer
Norcold refer not cooling properly
Turned on our Norcold 1211 refrig today. Started cooling as usual. Freezer got down to 10-12 or so, not as cold as usual but ok. Refer compartment leveled off at 50 deg. Set temp up far higher than usual but no change several hours later.
Checked coil and boiler in outside compartment barely warm to the touch. This was all on AC so I tried lp thinking ac heater may be defective. It will not light in lp mode it says “no flow”. Gas is on stove and water heater both lite right up. It worked fine in both ac and lp modes last trip.
Ideas, circuit board maybe?
