not sure where to post this.....
huskyfan68
Yes it's RV related (sort of...)
I have a 2009 F150 towing a 22' Wildwood. I would like to purchase a golf cart for campground use.
I believe a standard cart is a little less that 4' wide and should fit with tailgate down....
Here are my 2 questions:
1. Can you still tow a TT with the tailgate down?
2. Can you drive an electric cart up into a pickup with ramps?- Meaning does it have enough power to get up into the bed..
19 REPLIES 19
huskyfan68
thanks- i think the way to go is with something like the Cricket carts. they are much smaller and lighter (300lbs)- I believe one will fit with the tailgate closed but will confirm. Yes I am aware not all CG allow. Most of the ones I go to do- The ones that don't- i will leave it home
valhalla360
Nomad III
Nomad III
PastorCharlie wrote:
A cart can be loaded with or without a tailgate.
With a long bed, yes.
With a short bed, you need the tailgate or an axle will hang off the end of the bed.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
PastorCharlie
I had a 7,000 lb. construction trailer with the flip up jack. Pull pin and the jack will fold up along side of tongue.
Removing the tail gate is a two minute job.
valhalla360
Nomad III
Nomad III
JimBollman wrote:
Assuming weight and other clearances check out here is a possible fix for the trailer jack being in the way of the tailgate. I bought Jack-E-Up for my car trailer so I could drop the tailgate with the trailer attached. Works good. http://jebs-stuff.com/Camping/Jack-E-Up.jpg
Just get a boat trailer jack. You pull a pin and they rotate 90 degrees to be flush with the A-frame arm. It's a 22ft trailer so likely only 500lb hitch weight loaded.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
JimBollman
valhalla360
Nomad III
Nomad III
dodge guy wrote:
In a short bed the tailgate will hit the Jack. If you donโ€™t have a tall Jack the corners of the tailgate will be driven into the front of the trailer.
However....after you load the golf cart into the F150, what are you going to use to tow the trailer?
Depends. Some trailer A-frames are longer than others.
We have a short bed (but that's a sore wound). We can lower the tailgate while hooked up without hitting the jack. Going down the road on typical turns at intersections, the tailgate wouldn't be an issue. We could probably get the truck at a 30degree angle to the trailer before we would have to worry about hitting anything, so it would take a little extra care backing into a tight spot but generally doable.
The OP would need to check out the dimensions on his setup to be sure.
I assume after loading the golf cart, he is planning to tow with the F150. It's the feasibility issues, he's trying to work out.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
wanderingbob
Also , you can take the jack off and rig it to go off and on quick with thumb bolts !
Reisender
Do they make golf carts with lithium batteries? That might help with the weight.
bukhrn
Besides the Technical aspects already mentioned, you might want to consider the fact that not all CG's, public or private, allow golf carts, unless you're only going to a specific one that you know does.
2007 Forester 2941DS
2014 Ford Focus
Zamboni, Long Haired Mini Dachshund
Grit_dog
Navigator
Navigator
huskyfan68 wrote:
thanks- so I guess a good follow up question would be- would it work with the tailgate removed?
A follow up response would be, measure length of golf cart, measure length of bed, see if tailgate hits trailer jack and check your payload vs all the weights.
dodge_guy
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
valhalla360
Nomad III
Nomad III
Hook up, lower the tailgate and start backing up to see how sharp you can turn. It might be Ok. It might NOT. It may be possible to get a hitch extension since it's a small relatively light travel trailer which would help push the pivot point back.
Yes, you can drive it up ramps into the back of a pickup. With a long bed, it should be possible to close the tailgate.
The bigger issue is payload. Gas golf carts are upwards of 600lbs and electric carts can be upwards of 1200lbs (batteries are heavy). Good chance by the time you load up the truck with people and gear, add the cart and add the hitch weight, you are over a 1/2 ton trucks payload.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Bobbo
I agree with fj12ryder and Second Chance. As much argument as there is on this forum about whether an F-150 even has enough payload to tow a decent sized TT, putting a golf cart in the truck bed is guaranteed to throw you FAR over the payload limits when the TT is also hooked up. Note that Lakeland Bob at least had an F-250 (equivalent) when he got his.
Bobbo and Lin
Lakeland_Bob
There is a cart made to do just what you are asking for. It's called a Cricket" https://cricketminigolfcarts.com/cricket-golf-cart-models/.
We had one and carried it in our 2500. It compacts for transport at 58" by 32" and weighs 330lbs + any accessories. They are very well made, use some standard parts. However, they can be a little tippy due to their narrow wheel base. They will carry 4 people and get around pretty quick.
We found ours on Craigslist for $2400 and sold it latter for $2600.
