Tootalltony__'s avatar
Nov 21, 2023
Onan microquite 4000 dies after 30 min
  • Does it die and then restart? Or does it have to rest before you can restart it?
    How is your fuel? Any chance it's bad gas?
    Luckily the carbs are very easy/cheap to replace on the Onans. You can find one on Amazon for under $100 in under an hour. I think I bought THIS ONE a few years ago and it worked great. Plus it was so cheap I bought a spare to keep with us. I figure if we're using the gen then we're probably out in the sticks and don't have another power source except for solar.
    Regardless though, you really need to add some info to your original post. You should be able to go back and edit that post to fill in some blanks with details.
  • Thinking we need a lot more info. Is your oil level right, is there over 1/4 of fuel in the RV, is it overheating? When it dies it should throw a code - a series of flashes on the panel. Google what that series of flashes means and it will tell you what the problem is.
    This question might get more traffic if it were in the technical help forum instead of tricks and tips.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
