- WeeluvdisExplorer
Dandy Dan wrote:
Weeluvdis wrote:
If you've owned a FW and a TT which one do you like better and why? In your opinion is one easier then the other to back up and hook up.
We have had 3 TT and are on our 2nd 5er. You will get less weave out of the 5er and with the hitch being over the rear instead out from the back your pivot point is further ahead. If you have never pulled a 5er,soon as you get used to it you will wonder why you didn't do it before. You can put a 5er in some places hyou might not be able to get a TT just because of the about of pivot you have. Personally, I will never go back to a TT. Good Luck in your search and Happy Camping.
Thanks for this info. It's what I was looking for and why I asked opinions from people that owned both. We are definitely looking to trade but have to see how much we will lose. I look forward to travel to the Great Smoky Mountain National Park with a FW. I don't want to go there with the TT. - rhagfoExplorer III
pnichols wrote:
I gather from all I read in the forums that TTs and 5'ers with built-in generators, and built-in fuel tanks for them (other than propane) ... are unusual.
Hauling fuel (other than propane) around in a tank in a detached towable would make me "nervous", but of course it is done and gotten away with.
We really enjoy our built-in Onan fed from the main 55 gallon chassis gas tank. :)
Most toy haulers have a fuel tank so you can fill up the toys!
I would worry about having 55 gal of gas in my truck, 55 gal of diesel a bit sleep as it has a higher flash point. - Dandy_DanExplorer
We have had 3 TT and are on our 2nd 5er. You will get less weave out of the 5er and with the hitch being over the rear instead out from the back your pivot point is further ahead. If you have never pulled a 5er,soon as you get used to it you will wonder why you didn't do it before. You can put a 5er in some places hyou might not be able to get a TT just because of the about of pivot you have. Personally, I will never go back to a TT. Good Luck in your search and Happy Camping. - pnicholsExplorer III gather from all I read in the forums that TTs and 5'ers with built-in generators, and built-in fuel tanks for them (other than propane) ... are unusual.
We really enjoy our built-in Onan fed from the main 55 gallon chassis gas tank. :) - colliehaulerExplorer III
pnichols wrote:
My 5er and all of my TT's (except the seasonal) have built in fuel tanks and Onan generators.
The main problem with TTs and FWs ... that motorhomes solve, is where and how do you carry enough fuel in the RV for a built-in generator for use during warm weather drycamping?
Propane is not very good - it's used up too fast running a built-in generator. Diesel is not very good - it's smelly/oily, and diesel built-in generators are often too loud and are heavy. Gasoline can be dangerous to carry around in large enough built-in tanks on TTs and FWs for built-in gas generators to be useful.
Carrying a generator and fuel in the TV is about the only choice, but then you lose A/C in the RV if someone stays behind in warm weather, or if this isn't the case, the RV can warm up to very high hard-to-lower-later interior temperatures while everyone is gone in the TV.
:h - colliehaulerExplorer IIII own both a 35' 5er and several TT's from 17' to 35'. People have already covered towing well. I will cover use. If you stay in RV parks a 5er is fine. Where a small TT shines is the older small tight campgrounds and forest. I don't like the 5er bedroom as much as my seasonal TT. The 5er bedroom has lower ceilings 72" compared to 87" in my TT. Towing I like the 5er, Living in I like the TT. Both have +/-, you have to decide what works best for you and where you camp. Very few high end TT made and tend to be entry to mid level, lots of choices for high end 5er's from entry to high end.
- pnicholsExplorer IIThe main problem with TTs and FWs ... that motorhomes solve, is where and how do you carry enough fuel in the RV for a built-in generator for use during warm weather drycamping?
:h - Cummins12V98Explorer III
fireman93514 wrote:
We had one TT and 3 different sizes of FW. We switched to the MH only after crushing a vertebrae and had difficulty hitching up and using manual jacks we had. Now we are thinking of going back to the FW.
Most return to a 5er. - TXicemanExplorer IIA 5er generally pull better and has more storage space than a TT.
5ers now come with automatic hydraulic leveling systems so that old argument is now gone.
Ken - fireman93514ExplorerWe had one TT and 3 different sizes of FW. We switched to the MH only after crushing a vertebrae and had difficulty hitching up and using manual jacks we had. Now we are thinking of going back to the FW.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
