Grumpy374 wrote:
OK everyone, read---important---understand!!!
Key into ignition---nothing will happen>
Turn to FIRST CLICK / POSITION. THIS IS THE ACC POSITION.
The second position is everything is on, and will run your battery down. The second position is where the key returns to after you release it after starting the engine.
The first position is called the acc position because it allows you to turn on radio, ect. But the car itself is not powered up.
The FIRST ACC position is where you want it to be. This unlocks the steering gear so the front wheels will turn and track with the rv.
Grumpy
This is wrong.
Key in ignition, steering wheel still locked.
Turn 1 click, steering wheel unlocked, but NOTHING electrical activated.
Turn 2 clicks, this is the ACC position
Turn 3 clicks, this is RUN.
Turn 4 clicks, this is START.
The third position is where the key returns after you release it when starting the car.
If your Subaru works like you describe, it is the only one I have ever seen or heard of that does.
ON EDIT:
I think I know what you are doing. The first click is much less noticeable than the second click. Try this. When you get to what you THINK is the first click (the ACC position) try turning the key back towards "off" WITHOUT pushing in on it. If it turns back a click then stops, but is still locked in where you can't pull it out, you are just not feeling the first click.
