โFeb-20-2016 07:34 AM
โMar-20-2016 09:32 AM
โFeb-22-2016 10:29 AM
โFeb-22-2016 05:53 AM
bid_time wrote:I know how they work, and have one. However, the answer the poster gave was incomplete, and I merely was pointing out that "two jumper wires and a battery" won't work if the motor has failed.fj12ryder wrote:You disengage the motor and roll it in. Quite similar to what you would do if the spring broke in yours. My recommendation though would be for you not to buy one, you clearly have a preconceived bias. The OP's question was "can you...", the answer is: yes.wing_zealot wrote:And if the motor is shot?Retired JSO wrote:Not really, simply two jumper wires and a battery.
Carefree and Dometic power awnings require an act of congress and an RV tech to use manually.
โFeb-22-2016 05:13 AM
Lynnmor wrote:You'll probably never need to know anyways.SoundGuy wrote:
Here's a novel concept - read the awning owner's manual which describes how to manually roll up a power awning that's not cooperating, even if the motor itself is shot. :S
Not in my manual.
โFeb-22-2016 05:10 AM
SoundGuy wrote:The problem is the people that don't have a power awning don't have an owner's manual to read but still think they have all the answers. So when an OP, who may be considering an RV with a power awning asks a legitimate question; you get uniformed answers from the unknowing.
โFeb-22-2016 05:03 AM
โFeb-22-2016 04:20 AM
โFeb-22-2016 03:46 AM
โFeb-21-2016 06:16 PM
โFeb-21-2016 06:15 PM
wing_zealot wrote:Retired JSO wrote:Not really, simply two jumper wires and a battery.
โFeb-21-2016 05:52 PM
โFeb-21-2016 05:26 PM
โFeb-21-2016 07:30 AM
โFeb-21-2016 05:42 AM
