Rick Jay wrote:
I have a question: For all of you who shut the water off, do you make sure to shut off the water heater too? It would be bad if the leak caused the hot water tank to drain and then the electric and/or gas heater kicked in.
I don't turn off the water heater. I never leave the propane element on, just the electric element. If the water heater were to drain, the electric element would burn out quickly. Otherwise, no damage should be done. The electric heater element is cheap and (relatively) easily replaced.
