escapee66's avatar
escapee66
pullrite 4400
i recently bought 5er that came w/pullrite slider 4400 hitch...previous owner towed w/shortbox...i own a 2500hd LB..will this hitch work ok...i hear its a great hitch and i know i dont need it w/LB but hey it was included...your help will be much appreciated
  • thanx for the tips folks...got a universal pullrite kit for 4100/4400 for my 01 2500hd 8ft bed fit great easy to install and the hitch works flawlessly...thanx again...happy trails...
  • 2112's avatar
    2112
    Call Pullrite customer service and tell them exactly what truck and hitch you have. They will tell you what you need and where to acquire it. They are great people to work with. You may be able to get away with a universal mount kit but they would confirm this.
    If you plan on mounting it yourself the template is worth the $$.
  • great i figure so...the hitch already fits the 5th..came w/from folks i bought 5th from...it came w/everything quick release pins/rails...no frame mounts...cant seem to find them..do ihave to buy a kit...previous owner had mounts that meet bottom of bed..he kept: (..
  • The hitch should work just fine. You'll need to buy the proper rails. Pullrite sells both in bed and under bed. The latter is more expensive but allows easy removal of hitch when you need a clean bed. You will also need a Pullrite capture plate for your particular 5'ers king pin. While they do have a universal weld on it is HIGHLY recommended to get the specific one for your king pin. It mounts with 1 single screw making it very easy to take on and off when needed.
    I have a superglide on my SB Dodge and find it a very solid easy to use hitch.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 18, 2025
