Fordlover wrote:
dnmccoy wrote:
Excuse my ignorance, but I got the go ahead from my better half to start researching a camper for us! I have a 2007 F150 and got the specs from the link below:
http://www.fordf150.net/2007/2007-ford-f150-specifications.php
It says my max GCWR is 14,000lbs and that my max loaded trailer weight is 8600lbs. I saw something in my owners manual that's said if you do not have the towing package that the max loaded trailer weight is 5000lbs. Which is right?
Thanks!
Something is wrong with your info. Based on this chart ford towing guide page 16 your truck can only have a GVWR of 13,500 or 15,000.
I hope you mean GCWR, as I have yet to see an F150 or any typical half ton 15 series truck with a gvwr of 13500-15K lbs!
ANother thing that many do not think about, is aerodynamics, and frontal areal. At one time Ford used to give you the max trailer wt ratings with up to 80# of frontal area, reduce this by 2500 lbs if 80-100#, and another 2500 or 5K total if in the 100-120# range.
Airstreams by there round nature, and lower to the ground, will pull upwards of 10-15% easier per there brochures. Aluminum sided trailers vs a smooth fiberglass trailer of the same brand etc, while the fiberglass trailer may be 300-600 lbs heavier, it will pull easier, and worth it in my book/opinion to get vs the lighter one. Even if I was over a Mtw or gvw frankly!
As also noted, MTW you can tow is about as clear as mud to figure out. If your truck is at gvwr before hooking up a trailer, you have NO trailer tow capacity. If you have 500 lbs of free payload, you have upwards of 5000 lbs of total trailer wt between the axels and hitch wt, assuming 10% HW., 500 hitch, and 4500 in axel wt. If you want to tow a 5W with upwards of say 25%, you are limited to a 2000 lb total wt 5w, 500 lbs of hitch, 1500 in axel wt!
Marty
