riven1950's avatar
riven1950
questions on battery charging
I have a small 110V battery charger, nothing fancy , I think it has 2,6,10 amp selections.
Anyway, I was thinking about hooking short wires to the + and - terminals of my battery permanently and let them stick out of the battery box to make for easy charging. Not sure what you would call them, I'll call them pigtails.
Does this make sense? How would they connect to the charger which has aligator clips on it? Are these commercially available?
Other question concerns charging. I have always disconnected my battery before charging or turned off my battery disconnect switch.
Does it hurt to use a 110v battery charger while the battery power to the trailer is on and the frig is running on propane?
I have a 2017 Coachmen TT with one battery if that matters.
Not a battery expert obviously, just trying to be safe.
Thanks
