kfp673's avatar
kfp673
Jun 20, 2019
Quick Connect Outdoor shower
Hello All,
So our new (new last summer) trailer has a quarter turn disconnect style outdoor shower hookup. Our older trailer had a standard shower and the head stayed in the compartment. This came with the slinky style hose which also has the quick connect style on the end. Do they make shower heads with this connector on it? I can seem to find one? Or possibly an adaptor? Thanks
  • Since the thread on the hose is the same as a garden hose, we just use a sprayer nozzle on ours.
  • ependydad wrote:
    Landroamer1 wrote:
    Mine has the 1/4 turn on one end of the coiled hose to hook to the fixture , and the other end of the hose is standard 1/2" male pipe thread.
    Same.
    Finally had a chance to play with this a bit more. Mine also has the same. The problem is I want to use the old shower head I took out of the campers shower and that is smaller and does not fit. I was actually thinking my coil hose is 3/4". Looks like normal garden hose?? Anyway, I need the larger female to the smaller male so I can use the shower head. Guess I will dig around to see what I can find. Thanks all!
  • wa8yxm's avatar
    wa8yxm
    BillyBob Jim wrote:
    Having had outside showers on 4 different rigs over the years I have yet so see the benefit. The only thing I've found them good for is washing the dog.
    I call it "The dog shower" and I don't even have a dog so you got a laugh out of me. (This is not criticism of your post in any way)
    IT is actually for rinsing the waste dump hose after you dump or so I believe, can also be used to rinse off sand after a hike to the beach but. hey.
    To the O/P.
    They make a 1/2 inch quick disconnect. it is not a quarter turn (it works like the 3/4 inch garden hose qd's you find in any lawn and garden section but 1/2 inch) and it will fit your outside shower
    Any full service plumbing supply can get 'em.. I've seen 'em in some state parks where they use 'em for the handicapped shower wand and store it in the off season.
    First one I found
    Same.
  • Having had outside showers on 4 different rigs over the years I have yet so see the benefit. The only thing I've found them good for is washing the dog. Although according to some on RV boards you'll go to the federal penitentiary if you use it and get one drop of soap on the ground. In the least you'll damage the entire ecosystem.
    The one we had with the slinky hose and quick disconnect simply had a standard 3/4 garden hose connection on the business end. Not really an outside shower per se, no hot connection cold only, more like a dog hoser than anything. Pretty easy to adapt some type of handheld shower head to the 3/4 hose connection with some off the shelf fittings.
  • RoyB's avatar
    RoyB
    This doesn't address the shower hose but recently had a small roof leak at my house where the toilet vent pipe goes thru the roof...
    Went to local hardware store and found one of those three inch high and maybe 30-inches round plastic tubs that has a hose connection on it...
    Very inexpensive... These are normally used to sit a water heater in it and give a way to trap water run off from a busted water heater
    Google image
    I got to thinking this would be perfect for using with the outside shower setup... You could run the drain hose away from the trailer into the grass somewhere...
    Roy Ken
  • Mine has the 1/4 turn on one end of the coiled hose to hook to the fixture , and the other end of the hose is standard 1/2" male pipe thread.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
