austondog's avatar
austondog
ram 1500
I have 2012 allegro bus thinking of getting a ram 1500 rwd diesel for toad does anyone have any insight on this
  • thanks all I'm thinking cc 5.5 bed and as to rwd I'm not offroad much rwd is lighter and cheaper I need diesel for pulling 16" trailer with small tractor. I will look into drive shaft disconnect thanks
  • As noted in my Signature, I have a Ram 1500 EcoDiesel. And, from the others, you want either 4X4 or you will need a driveshaft disconnect installed. Also, not sure what you're looking for, but the EcoD is available in Std Cab 8' bed, Quad Cab (extended) 6.4' bed, and Crew Cab 5.5' and 6.4' bed. Unfortunately, it is not available in Std Cab 6.4' bed.
  • tatest wrote:
    You will probably be disconnecting the driveshaft on the truck every time you tow it, unless you can get a transfer case that locks into neutral, which means 4x4 rather than RWD.
    X2 It MUST be a 4X4 to flat tow it!
  • You will probably be disconnecting the driveshaft on the truck every time you tow it, unless you can get a transfer case that locks into neutral, which means 4x4 rather than RWD.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 20, 2026
