One of the handles that you twist to unlock the arm broke off. They have been getting harder to operate. We’re on a trip, here for a week and was concerned about towing with it.
I opened the PDF and learned that there are 1/2 holes on the arm and you can put a bent pin in to bypass the unlock assembly. OK. I can still use the tow bar.
Mine is fifteen years old. I also learned they added a zerk to lubricate the locking ass’y.
Mine doesn’t have that. I never lubed it as I’m hesitant to lube things behind a diesel as you combine grease, carbon, sand and you have a grinding slurry.
They advertise a lifetime warranty so I think when we get back I’ll send it in for a rebuild/repair.
I received good service from them in 2006 when were rear ended and required repair.
If not I’ll buy some parts and do it mice elf.
My Kharma ran over my Dogma.
