Hi Folks, I've gotten great advice on a general question on towing a toad (10 year 5er owner just switched to a motorhome.) Very strong recommendations on the Ready Brute system. I am also a member...
His cable is still too tight. If it is adjusted properly, you can pull the car end of the brake cable forward enough to unhook.
Even if you can't pull it hard enough, you take a lock pin out of the clevis pin that holds the loop on the Ready Brake, and that end is laying in your hand.
This is all that is holding the Ready Brake end in, and is EASILY removed.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
