May-11-2017 02:58 PM
May-29-2017 05:38 AM
May-28-2017 09:12 PM
N-Trouble wrote:
Put a set of Timbrens on your Ram and it will ride a lot better. They will provide both load leveling and side-to-side sway support. Sway bar will only provide side-to-side. Timbrens are cheaper and take 10min to install.
May-28-2017 07:43 PM
May-28-2017 07:35 PM
May-28-2017 05:28 PM
May-24-2017 02:57 PM
rhagfo wrote:Nevadastars wrote:
That's pretty much what I was thinking too BenK, since all the weight is over the center of the truck axle at all times. I still may get one for it eventually, sure can't hurt. One for the fiver would be great for the high winds here in Nevada, but doubtful anyone makes one.
Nice 5er just looked at the specs.
I stick by my earlier statement on the TV rear axle sway bar, I would seriously look at one. It is not a major change to the suspension, it will stiffen up the rear just a bit, but what it will do is resist the roll caused by heavy side winds.
In addition if the 87 gallon H2O tank is in front of the axles run with it FULL, I know on my Copper Canyon rides and tows much smoother with a full tank of H2O.
The other thing the Camper Package cam with that year was the same springs as the 3500, so that likely helps also.
May-24-2017 02:43 PM
May-24-2017 12:23 PM
May-24-2017 11:46 AM
May-24-2017 11:39 AM
May-24-2017 11:24 AM
Steakman wrote:
I never knew there was such a thing - Sway bars for 5th Wheels...Who knew.??
...Anyone care to post some pictures..??
thank,
Stk
May-24-2017 11:17 AM
'06 GMC DMax CCSB 594,545 km
(368,890 miles)
2003 Citation 26RKS
.May-11-2017 07:12 PM
May-11-2017 06:46 PM
Durb wrote:
Interesting question: Does side pressure from wind induce axle steer on hung axles? I bet there are some engineers here that can answer that question.
Not to be flippant but are all the wear parts on your suspension such as shackles and pins and this and that nice and tight and in new condition? I'll bet yes, did you have the front suspension recall done on your truck? My son has an 07 2500, which is lifted with larger tires, and he has a hard time keeping it in the lane empty.
I like your real name.
