- pianotunaNomad IIIIf possible replace with a "real" box and outlet.
- SoundGuyExplorer
NanciL wrote:
How do I get a 120 volt receptacle and plate out of the wall in my trailer? There are no screws showing.
I am guessing I have to pry the cover plate off, but figured I would ask here first.
It's just a garden variety Speed Box Duplex Receptacle ... just carefully pry off the cover which is secured in place with a couple of plastic tabs to gain access to the receptacle itself. - some have small points on the back of the cover plate that snap into the receptacle. You would need to pry the cover off.
- LynnmorExplorerPry off the face plate and then turn the screws on opposite corners. It may take many turns to remove the outlet.
- MfanExplorerProbably 1 piece. Work 1 side at a time
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
