โMar-25-2021 05:13 AM
โApr-15-2021 09:29 AM
time2roll wrote:Lynnmor wrote:I am not sure how to cut a figure 8 inside the bushing... I did file a relief or chamfer around the grease exit to help the flow.
I suggested several times on this forum to cut a figure 8 inside the bushing to allow the grease to distribute away from the grease hole. You can't get enough pressure to force it thru a tightly blocked hole. Expect more joints to stop flowing as the wear will cause a better match and more perfect blocking.
โApr-15-2021 08:32 AM
โApr-15-2021 08:23 AM
โApr-15-2021 05:28 AM
โApr-14-2021 03:58 PM
time2roll wrote:
Have heard stories of bolts not drilled completely. Also bolt holes under pressure may not pass the grease through. Try unloading them first then probably need to remove for inspection.
โApr-13-2021 09:51 PM
โApr-13-2021 09:24 PM
โApr-13-2021 07:25 PM
โApr-12-2021 11:14 AM
JRscooby wrote:cummins2014 wrote:Cummins12V98 wrote:
Glad you got it handled. Grinder and slitting disk would have saved you a lot of stress and exhaustion.
Oh!! , but it's more fun with a cheater pipe ,and busted knuckles . :B
Inexperienced operator in close space that spinning wheel can do more than bust knuckles.
โApr-12-2021 09:11 AM
โApr-12-2021 07:01 AM
โApr-12-2021 05:31 AM
โApr-11-2021 07:43 PM
โApr-11-2021 08:26 AM
