GaryS1953
May 29, 2018Nomad
Repairing structure - 2 questions
As some may remember from earlier posts I recently discovered some water damage that mainly affected flooring and one wall. Most of the repair was pretty straight forward, take stuff apart, and replace. My camper is older and the bottom under the flooring joists is a vinyl material. As I went to staple it back into place my brand new Bostich electric staple gun could not or would not fire the staples through the soft vinyl material and into the pine wood behind it.
Question 1. Is it just me, or is there some trick to using these electric staple guns. Admittedly it was a cheapie, only $30 at Lowes, but this seems like a simple straight forward task. If I need a better one, what to you recommend? I can and will take this one back Lowes.
Question 2. The vinyl bottom material is the only thing between my flooring and the outside, and I've noticed a few minor nail hole size holes. What kind of patching works best on this material?
Thanks in advance for any input.
