RV Countertops
dedmiston
Moderator
Moderator
Our toy hauler has kind of cheap faux granite countertops, but they look pretty good in the context of our RV. (Not sure what the material is called.)
My wife wants to replace the wooden island counter with this same material, but I don't know where to begin to shop.
Has anyone replaced their RV countertops? Where did you get your materials? Is this a DIY project, or did you hire someone to do it?
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โ€ข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โ€ข <\br >Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
6 REPLIES 6
neschultz
dedmiston wrote:
neschultz wrote:
Not sure if they carry what you want but Iโ€™ve bought a few different types of countertops from Solid surface over the years.
That looks pretty good. Do they offer a bull-nose?
I know they offer different edges on the Pre-Made Corian vanity tops. Not sure on the pieces.
Norman & Janet with Minnie the Weiner Dog
2005 SunnyBrook 38 BWQS 5th Wheel (stationary in FL for snowbirding)
stickdog
Just google "solid surface countertops near me".
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
โ€œA good traveler has no fixed plans, and is not intent on arriving.โ€ Lao Tzu
dedmiston
Moderator
Moderator
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
neschultz
DrewE
I would guess it's a laminate counter (e.g. Formica), a thin layer of a plastic sort of material on a substrate of plywood or particle board or similar.
You should be able to find laminate materials at most building centers/big box home improvement stores. They are not too hard to install on flat surfaces (using a contact adhesive). Square corners are also pretty easy to do, with trimming router bits to square up the edges of the laminate, but curves other than quite gentle ones are rather impractical for DIY installation (at least to my understanding).
You could also replace the whole counter top, rather than covering it with a laminate; there are many options available. Some can get to be rather heavy if the island is large.
fj12ryder
Our toyhauler has the Corian material countertops. Perhaps yours is similar.
Howard and Peggy
"Don't Panic"
