oilslick
Feb 25, 2014Explorer
motormike73 wrote:
tires are rated at 65mph
as for welding a perch, i assume its not TOO tough of a task to measure/center holes on the perch (where the spring center bolts would sit into)? that was my concern with how difficult it would be to get it centered...
I think it's a very simple job that you could easily do yourself if you can weld, if not then I'm sure most trailer shops could do it for you. The axle tube looks to be 2 inch so a couple pieces of 2 inch x1/4 flat stock with a hole drilled in each piece carefully measured in from the outside end and centered, then any welder could stick it on.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 22, 2025
