Tacswa3's avatar
Tacswa3
Shower Caulking
So I caulk the shower in my TT where the walls meet the tub. I missed the small writing on the tube of caulk where it said "silicone based"
Applied first coat, stepped in tub and moved around to help caulk settle into and seat and waited for it to cure. As expected, a second application was needed so I apply. Shower was used 24 hours later and after a few uses I notice the caulk is peeling and coming off.
Where did I go wrong and how should I remove it so something else will stick? Can I use a Dicor product?
