jdc1
Aug 30, 2020Explorer II
To repair it correctly, the entire filon sheet needs to be removed. To fix it for now, drill a hole in it small enough to insert spray foam. Then, with trailer next to a wall, put a piece of plywood over the affected area. Use 1x2's to put pressure against the plywood (1x2's against wall and plywood).
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,105 PostsLatest Activity: Jan 25, 2025
