Larryect
Sep 26, 2018Explorer
Slide topper interfering with slide seal?
I don't remember my kitchen slide not going out all the way before this year. I recently noticed when open all the way it appears to be sealed at the bottom but the top is not as tight as it should be along the wall.
The trailer is about 6 years old. Slide toppers were put on right after purchase.
I took it into a local dealership to have it checked out. The service tech says it is the slide toppers tension keeping the slide from sealing at the top so he didn't feel that he should adjust anything. He says he verified by pushing the slide out from the inside "using a wedge"
So, at home I extended the slide and then checked the tension on the toppers roller tube. It was tight but I could still turn it further by hand. The slide may have moved a little, but still not as tight as I would expect.
The slide seems to close fine and be tight all around.
Thoughts?
Thoughts?
